NOISE IN REVERSE
Old 10-14-2008, 07:31 PM
EL_OREO10's Avatar
Default NOISE IN REVERSE
I RECENTLY BOUGHT A 94 CAMARO. I DONT KNOW ALOT ABOUT CARS BUT I WANT TO LEARN HOW TO FIX MINE UP. WHEN I SHIFT INTO REVERSE IT MAKES A LOUD NOISE. THE ONLY WAY TO SHIFT WITHOUT IT MAKING THAT NOISE IS IF I SHIFT INTO ANOTHER GEAR FIRST. I DONT KNOW IF ITS THE CLUTCH OR TRANSMISSION BECAUSE WHEN IM DRIVING AND STEP ON THE ACCELERATOR HARD THE RPMS GO UP ALOT AND A COUPLE SECONDS LATER IT STARTS TO GO FASTER. I DROVE OTHER CARS AND NONE OF THEM DO THAT. SO ANY HELP WOULD BE APRECIATED.
Old 10-14-2008, 08:44 PM
importmd's Avatar
Default RE: NOISE IN REVERSE
sound could be slop in the drive shaft, or rear end which most cars have, unless its real bad then it needs to be fixed. and it sounds like your clutch is slipping
Old 10-16-2008, 07:36 PM
th3po1son's Avatar
theres a button on your keyboard that says "caps lock"
press it
B_Dubya
03-27-2015 02:10 PM
chevycrazy32
03-26-2011 09:27 PM
boylemyster
09-05-2010 12:14 PM
bryans3.4 95
10-27-2008 12:40 AM
69dmz
67-69 V8 Tech
10-19-2008 09:26 PM
Quick Reply: NOISE IN REVERSE
