95 Camaro Cranking Problems - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 08-13-2010, 01:33 PM
Default 95 Camaro Cranking Problems
Will start fine for a while no problems.Then it will be a butt and u have to turn it over and over and over and it will eventually crank up sometimes it may take ten secs other times twenty or more. Wires all look good as far as i can tell. Just wondering if anybody else has experienced this problem and what it took to fix.
Old 08-13-2010, 01:37 PM
so its turning over but will eventually start, how long from the last time it had new plugs? is this a lt1 or v6?
Old 08-13-2010, 01:49 PM
We just had the motor rebuilt a year ago and its been fine up till a month ago. Once it cranks there is no lack in power it has a comp cam and all new sensors, fuel pump and filter, does it more when it is hot but will do it when it is cold also, thinking it may be the ign module or switch. Just hoping somebody else has had problem and figured it out being how much those parts cost.
its a 3.4 L
Old 08-13-2010, 02:14 PM
check plug wires and coil wire. sometimes the coil wire is not pushed in all the way and it can eat the end of the wire off. take the fuel filter off and dump contents into a clear container and check for crud or water. if clean reinstall if you like. or change if you like. lol. if you have access to a fuel pressure tester check fuel pressure. try turning the key on and off a few times before turning it over and see if it starts right up. if so it could be fuel pump or fuel pressure regulator. pull the vacumm hose for the fuel pressure regulator off at the manifold and see if theres fuel in it, if so fpr is shot. and for piece of mind you may want to test the evap system. sticky on the top of the lt1 section.
Old 08-13-2010, 03:14 PM
When you turn the ignition on, not to run, can you hear the fuel pump prime? Maybe the pump relay isn't working, and the engine finally starts once your oil pressure builds high enough to send power to the pump. The oil pressure sender is used as a fail-safe backup in case the relay fails.
Old 08-14-2010, 08:42 AM
that was the first thing i listened for when it started this crap and i hear it everytime when u first turn the key. im going to have a friend check and see what codes come up on it within the next week.
Old 08-14-2010, 12:13 PM
mymaro4's Avatar
On The Tree
I know this sounds a little to basic but have you checked the terminals on your battery? My positive post connection was really loose (I'm assuming from all the rumble under the hood) and it started fine every time, UNTIL- ya that one time and I had to tighten it, jump it and its been fine ever since. Or have Auto Zone check your battery - poss your alternator is going bad. I like to start simple
Old 08-14-2010, 12:17 PM
mymaro4's Avatar
On The Tree
second thought here- you say it cranks, sometimes it takes awhile- check your starter- I just replaced mine- thats a whole nother story
Old 08-14-2010, 04:00 PM
ill check both of those out. it don't have any problem turning over just doesn't seem to be firing or getting fuel. Im going to try and change out the oil pressure sensor and fuel relay and see what happens ive got a list of things to try from asking on here starting cheapest being unemployed at the moment and working up.
Reply
Thread Thread Starter Forum Replies Last Post
keeps cranking but mikes68 67-69 General 4 04-07-2013 09:22 AM
1997 Camaro Cranking and occassional Shut off Problem weasel348 93-02 V6 Tech 6 06-18-2012 11:07 PM
95 camaro 3.4L Cranking Problems help please allen707 93-02 General 8 09-20-2011 10:51 PM
Non Cranking 3rd Gen 91 Droptop General Tech 5 07-10-2011 02:32 AM
no cranking condition phillyfrankie General Tech 4 11-02-2007 05:04 PM
Tags
34, 34l, 95, camaro, change, chevrolet, chevy, cranking, diagram, extended, problem, relay, starter, turn, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
