replacing fuel pump
replacing fuel pump
ok im starting to think about replacing the fuel pump in my car can someone tell me exactly where i need to cut this access door and keep in mind i drive a convertible also is there anything special ill need to get the job done, any tips to make it easier, and is there anywhere i can get the pump cheaper than 181.99$$
thanx in advance
EDIT: if i can find it can i just replace the pump the 181.99 is for the entire sending unit
thanx in advance
did i show you this already? dont know the difference on a convertable. give you a general idea anyways.lol.
you can use just the pump if you wish. the oem pump is the way to go, the cheap ones are unpredicable. can last 6 months or 6 yrs.
I didn't cut hard lines? Do you mean in the rag tops? Thats a 4th gen hard top. I think the rag tops have a brace that might get in the way. If your putting a cheap pump in you want the access pannel. Chances are you will be doing it again. I got 3 weeks out of my $179 one. It didn't leave me sit but it got so loud I could hear over the radio.
I was under the impression design of the fuel pump assembly was similar between a 3rd gen and 4th gen.
If that picture is of a 4th gen and not a 3rd gen, then I am correct, you cannot remove the assembly without first cutting the hard lines due to the routing.
If that isn't a 4th gen and the design is different, ignore me
dropping the tank will be way to much of a btch to me it looks like the rearend will have to come out and im NOT doing that
sry craby i didnt notice you showed me that already thanx tho we all can always count on you for the answer
I see no friggin way where you have enough vertical clearance in a convertible to lift the sending unit up and out. I'm afraid you'll need to do it the right way. Btw, below is what my 3rd gen looked like. I made an attempt at doing the booby hatch, but there was absolutely no way to weasel the sending unit and pump up, rotate it 90 degrees, then up and out with all the l-o-n-g steel lines attached. So, I decided I didn't want to cut the steel lines and then have to flare at least the high pressure supply line to re-connect it correctly and safely. Could be the lines on the 4th gens can be disconnected and split? Not on 3rd gens though.
