94 camaro overheating
  #21
Old 04-09-2015, 06:39 PM
warmeck's Avatar
nevermind i figured it out but these Name:  output_zps69z7z8eo.jpg
well i can already tell that my camaro starts up strong the first crank now the coolant level seems to go up at a much slower rate. i am low on coolant though probably 60% full a lot of coolant fell out when i changed those sensors tried as much as possible not to get the opti wet because if the opti went i would probably just sell the car lmao. but i did not get it to operating temperature yet or get into traffic/stop and go to see if the problem is fixed;ran out of daylight. tomorrow i will fill the car up with antifreeze and see if it fixed the problem i will report back with information tomorrow.
  #22
Old 04-09-2015, 08:40 PM
MKCoconuts's Avatar
Those aren't what I was thinking of, but I know what those are. Haha.
Make sure you're filling up 50/50 or max of 70 anti-freeze/30 water. Too much antifreeze is just as bad as not enough.
  #23
Old 04-10-2015, 04:33 AM
bleed the air out of the cooling system. look at 1 here https://camaroforums.com/forum/93-02...rt-here-38462/
  #24
Old 04-14-2015, 02:44 PM
warmeck's Avatar
well my car is still getting very hot. i just went on an 20min drive and it got to about the lash white hash mark before the red any other ideas?
  #25
Old 04-14-2015, 04:37 PM
pull the thermostat and make sure its not sticking. if you have done that take it out again and make sure you have the right one and its in the right way. http://shbox.com/1/tstat.jpg
  #26
Old 04-14-2015, 06:49 PM
warmeck's Avatar
Duralast/Thermostat 4218 at AutoZone.com - 1 reviews
this is the one i bought.. what do u mean in the right way? i just put it in and sealed it back up? and i will pull the thermostat again to see tomrrow. im pretty sure i put it in wrong now looking at this shoebox guide...
  #27
Old 04-14-2015, 10:00 PM
warmeck's Avatar
this is the old one i removed Name:  IMAG0117_zpsnrpfnz6a.jpg
  #28
Old 04-15-2015, 09:37 AM
torque_is_good's Avatar
that's the radiator cap
  #29
Old 04-15-2015, 09:40 AM
you can pull the thermostat but be careful not to soak Mr Optispark. In fact, if he knows that there is coolant around, he does everyhting in his power to get some onto himself.
Anyway, pull the thermostat and just refill spillage with good ole water.
Water under pressure has a higher boiling point and you'll be fine for testing
If your car still overheats AND the air dam is in place AND it overheats going 30mph or faster, then the issue is elsewhere
  #30
Old 04-15-2015, 01:05 PM
warmeck's Avatar
i dont think my thermostat is opening i tried to test it in a pan via shoebox guide and it wasent opening? heres a pic of my old one
Quick Reply: 94 camaro overheating
