94 Camaro 3.4l wont pass Emissions in Cali
Old 03-20-2017, 01:22 PM
Thomas O'Connell's Avatar
Im just as confused as you, I know the check engine light works because i can manipulate it with a scan tool. Im not sure as to why there are no codes. As for it being a pcm issue I did think of that but I am saving that for last as I dont want to have to tow my car to a dealer to get the flashing done right.
I put bosch O2 sensors in, I have heard that these are garbage for the camaro, but unfortunately its all I can get my hands on without ordering them online.
  #22
Old 03-21-2017, 10:59 AM
95 camaro 406's Avatar
the gas cap needed to be able to vaper lock it was not so you replaced it right ,i still think you drive it 500 miles take it back should be it ,had it happen to many times times myself on 2 cars ,an if you had the battery unhooked both those things can do it everyone should know that??? guys ,unless you got further issues ,but those are the only reason i se people fail after replaceing that many things ,i was going to say that the gas cap along could have been the issues i never heard of injectors cousing is but i am sure it can happen ,again just takwe it to for some long rides after you get it on the road then take it back ,after that you need some to Diagnose any problems
  #23
Old 03-21-2017, 02:49 PM
everything is installed now, all new parts. Now its bogging down really bad. almost like its missfiring
  #24
Old 03-21-2017, 06:04 PM
make sure plug wires are going to the right plugs. check fuel pressure, check all your wires
  #25
Old 03-21-2017, 07:16 PM
just need to check fuel pressure but everything else is good. I think the ecm just needed some time to recalibrate to the new parts now its running just fine.
  #26
Old 03-21-2017, 09:44 PM
GaryDoug's Avatar
Yes, check the fuel pressure. If it is low, that could indicate a bad fuel pressure regulator on the injector rail which could be putting raw fuel into the vacuum hose attached. Pull the hose off and see if there is any fuel inside the hose. That could cause the excessive gas smell.
  #27
Old 03-21-2017, 10:57 PM
Everything seems better now that i have driven it a little bit. It has a misfire though with no check engine light, I am thinking coil packs. Will let you guys know when its all said and done.
  #28
Old 03-22-2017, 12:40 PM
So now i have a dead cylinder. Cylinder 6, I just ordered a master rebuild kit which should be in tomorrow. By this weekend I will pretty much have a brand new car... FML
  #29
Old 03-23-2017, 11:18 AM
sounds like the car is nickle an dimeing you now an other issues with those kinda miles are going to happen ,may want to think about another car the 3800 cars have more parts avaialable
  #30
Old 03-24-2017, 02:49 PM
Nah, not too worried about the money. I got my master rebuild kit in, motor is already out and stripped down to the block. Im about to take the heads and block in to get cleaned up and inspected. The heads look like ****, I still need to pull the crank and pistons but im pretty sure my rings are the cause of all this. In the end though im not to mad, I will essentially have a brand new car when its done.
Quick Reply: 94 Camaro 3.4l wont pass Emissions in Cali
