93 ls z28 no spark
if you have a distrubutor (aka opti) you do not have a ls1. i am going with lt1. test for power to the pink wire at the coil. you may have a bad igniton control/coil module or less likely a bad igniton switch. are you sure your not outa gas? have you tested fuel pressure?
QUICKB4C
06-15-2009 11:52 AM
