96 V6 Camaro
Old 03-25-2010, 03:10 PM
welcogos's Avatar
Default 96 V6 Camaro
Hey Guys, have to replace the heater hose assembly from the the firewall to the belt tensioner on a V6 3800. I found the elbow for the block but the hose assembly itself is not available, how can I convert the belt tensioner over to use regular heater hose, the tensioner has the two white twist caps to keep the hoses from leaking. any advise, thanks
Old 03-25-2010, 03:32 PM
osduck5's Avatar
Never seen anyone convert that part to use just hoses without some type of adapters. Check your PM's for details.
