2000 camaro
You are going to have to get the code(s) pulled. Like most of the sub systems in your car the air bag system has error codes that point a tech to where to start looking. Even knowing the code only tells the area/type of problem. You may have a sensor code but the sensor is fine but the wire running to the sensor or the connector is the issue.
There are a lot of parts that make up an air bag system and all those parts where designed and made by man which means they can break.
