Wipers stopped working but started to work randomly and stopped again
Old 09-21-2010, 08:36 PM
shinwolf14's Avatar
Default Wipers stopped working but started to work randomly and stopped again
Okay, here's the whole story from the beginning:
First off, one day I was driving and I got something on the windshield so I tried to spray it and wipe it off. It didnt work. I tried every other mode, they didnt work. When I bought the car, the wipers only worked in very low, medium, and very high, our of a lot of settings. The next day, I decided to see if they worked... they didnt so i left the switch on by accident. Well when I was driving about 5 minutes later, they started working. The next time I started my car, they didnt work again. So I dont think its the motor. So I decided to check to see if its the switch. So I took my switch out and put it in my girlfriend's Camaro and put her switch in my car. Well my switch worked in her car and hers didnt work in my car. So I am out of ideas. Can anyone tell me a reasonable solution to this problem. Thanks in advanced...
I dont think its important but i have a 94 V6 3.4L automatic
Old 09-22-2010, 08:55 AM
its the wiper motor brain aka curcuit board. you can buy the board only but when i got the motor out i was not going to do that again unless i had to so i got the motor and board.
Size:  29.9 KBName:  wipermotor2.jpg
Size:  32.5 KBName:  wipermotor4.jpg
Old 09-22-2010, 09:47 AM
dopez28's Avatar
Id check your wires and connectors. Kinda sounds like a loose connection. Same thing happend to me.
Old 09-22-2010, 09:55 AM
hay dope hows it goin. so where was the lose connection at on yours?
Old 09-22-2010, 11:41 AM
dopez28's Avatar
right on the connector on the motor. i could wiggle the wires around and get them to kick back on. and doing good, my misfires got fixed, the o2 sensor wires got melted to the headers lol, didnt tie that side up.
Old 09-22-2010, 12:14 PM
shinwolf14's Avatar
craby: maybe i am just over looking it, but where is the circuit board in the pictures?
Also, like I said, I only had 3 settings on my switch that worked for my wipers. Would replacing the motor make the other settings work?
Old 09-22-2010, 07:31 PM
rustyk1's Avatar
My 95 is still having that problem. Most of the time they only work on high, but just the other day they worked right. I checked the connection but the problem remains. Gonna take the motor out and check things out.
Old 09-22-2010, 08:04 PM
the board is in the motor housing, thats why i was saying if i was going to take the motor out anyways i was gona replace the whole thing so i didnt have to do it again to replace the motor. yah the board tells the motor when to come on and off. mine started out stoping on the wrong side then would not work on delay most of the time and then it wouldnt park when turned off. thats when i changed it.
Old 09-23-2010, 07:16 PM
shinwolf14's Avatar
Well... I replaced the motor... not fixed. Any other suggestions?
Old 09-23-2010, 07:46 PM
crab i was sure that was it, the wiper switch should be in the blinker arm, thats an easy change. ill look in the book tonight and see what i can find before you spend anymore time/money on it. got a soccer game to go to right now.
Quick Reply: Wipers stopped working but started to work randomly and stopped again
