shuts off only when stopped...but not all of the time... need some opinions?
My car runs stronge...but in the last week it has began to shut off once in a while when i come to a complete stop ...there is a little bit of stumbling but its mainly a very quick shut off... not much warning. It does not shut off going down the road only at stops...Im considering the fuel pump, baffle, or converter...i dont know! has anyone experienced this?!
(just want to include that the distributor, cap and rotor, fuel filter, idle air valve, throttle position sensor, MAP sensor, air charge sensor, air filter, wires, plugs, and ignition coil have all been replaced in the last 5 months) WHAT COULD IT BE!
Sure would be a LOT easier if we had some clue of the Make, Model, Year and engine size. Your name makes me think you posted in the wrong section, this is 4th gen 93-02. No caps and rotors here.
BTW assuming its a 3rd gen it kind of sounds like a dirty or lazy IAC motor.
Gorn....it is a 1992 Camaro RS... that is pretty much obvious considering my profile name includes 92rs and this is Camaro forum....im posting in all sections for all generations... Im trying to get all the info I can.
Also posting the same post in different section goes against site rules and with a low post count could get you bands as a spammer.
If you read Massey post he brings up a good point. Do you get to a full stop then it dies or does is stall out as your come to a stop? Of course we don't even know if its a automatic or a stick LOL.
I thought i would give this site a chance... never heard of it but it seemed like a good one... but obviously its not.... you all are a bunch of ******s.... i came for just advice not an arguement. find something better to do than argue with people who have a problem and want advice about their car... you shouldve replied "i dont know" instead of giving me a hard time.... im out.. this sit SUCKSSSS
