1997 Camaro RS.. Problems!!!!
Old 03-28-2009, 02:32 AM
mdawood's Avatar
Default 1997 Camaro RS.. Problems!!!!
So when i start my car, it RPM's at 4500 RPM which was the normal range. NOw it RPMS at 3000 at max Revving, and it sounds like its choking, not enough air going in. i changed the spark plugs, and i dont know what else to do. And another thing when i drive it, it goes around 25mpH max even though i floor it all the way. Please Help =)
Old 03-28-2009, 12:03 PM
greenarrow's Avatar
September 2009 ROTM
well check the basics. You already did the plugs, check the coils for spark, check the wires, check the fuel filter, get the fuel lines pressure tested. If that all checks out, I would say a computer problem maybe. Is the SES light on, any codes?
Old 03-28-2009, 03:50 PM
02StanGT's Avatar
Possibly the cat is plugged.
Old 03-28-2009, 07:41 PM
evilkal's Avatar
I'm thinking you got a bad bad problem with your Fuel Pressure Regulator lol.
Old 03-29-2009, 02:31 AM
mdawood's Avatar
Default 1997 Camaro Rs .. Problem!!!!
well the check engine light is on, and it has two codes. one is the 5th piston misfire and the second is the evab sensor.. and idk wut to do next..
santa6
10-23-2011 08:12 AM
Hazard29
04-15-2011 11:17 AM
Hazard29
01-30-2011 03:15 PM
dmc_12
07-08-2008 05:11 AM
Quick Reply: 1997 Camaro RS.. Problems!!!!
