1996 cranks but wont start
I have a 1996 RS that i just bought. It will crank but will not start. If it sits for a while it will try to start for about 5-10 sec. Had it running for a min or so on starter fluid, but when i quit spraying it died. Person i bought it from said it startes to sputter and died back in Oct and has been sitting since then. I think it is the fuel pump but looking for help ??
Posted this in the wrong section. This is the section you would post to tell how to fix an issue not ask a question. This should be moved to the 4 gen tech section.
FYI, sure sounds like a fuel pump but you should check it for power .
And moved to the 4th gen section it is.
Sure sounds like a fuel supply problem to me too. Put a fuel pressure gauge on the fuel rail and see what's going on, or not.
