Window guide broke off
Old Aug 27, 2012 | 12:11 PM
djsquare1's Avatar
Default Window guide broke off
There is a little black rubber piece that sits in the rail to guide the window up and down. It has broke off from the window rails and I can see it has previously been welded back on. I tried to JB weld it but failed twice.
I was thinking of trying to use nuts and bolts, and use the bolt head in the track.
Any suggestions so I don't have to buy a new window frame?
Of course I could just get it re-welded but don't know any welders.
Old Aug 27, 2012 | 01:09 PM
greenarrow's Avatar
September 2009 ROTM
Are you talking about the felt covered window guide? Get a new one, there are cheap and bolt it in. If you're stock one isn't bolted in then you have bigger problems. Post a pic if you're talking about something else.
Old Aug 27, 2012 | 02:55 PM
|m()d's Avatar
i bought a guide off ebay for 5 bucks it was for a 90 camaro and it bolted right in and fit perfect. I have a 98
Old Aug 27, 2012 | 03:15 PM
djsquare1's Avatar
This thing: http://htsmall.rickscamaros.com/asse...sku/736261.jpg
The one on mine has no thread, maybe thats why it was welded on. If I could find this part with the thread I could just use washers and a nut to stick it back on as there is a hole with no thread anymore.
Old Aug 27, 2012 | 04:29 PM
jkeaton's Avatar
Try a junk yard or ebay.
Old Aug 27, 2012 | 05:25 PM
find the part and part number, that should help for search
Old Aug 28, 2012 | 03:59 PM
djsquare1's Avatar
Thanks craby! It's a roller but can't figure out which one in the pic. Mine looks different.
It's the exact same one as the link i posted that attaches to the vertical rail. I found a few on e-bay for $15-$20 (ouch)
Old Aug 28, 2012 | 04:04 PM
greenarrow's Avatar
September 2009 ROTM
That must be a later model thing, I have never seen anything like that in either of my doors and I've been in those things a lot.
Old Aug 28, 2012 | 05:44 PM
ok my mistake. thats lt1 info. look here under your year. http://performanceworks1.com/PDF%20F...s%20Manual.pdf
Old Aug 28, 2012 | 06:47 PM
JoelP94's Avatar
I need another one of the rollers also as it broke off my power window's railing recently and i just had the time today to take my door apart and see what was wrong with it exactly.
