1993 won't start - fuel?
Old 04-19-2015, 09:04 PM
Camaro1969's Avatar
Default 1993 won't start - fuel?
I have a 69 with a LT1 swap.
It cranks but doesn't roll over.
I get 43 lbs at fuel rail , may go down to 40 after left for a few min . during cranking the gauge goes down a bit .. 30s.. Is this norm? I replaced the inline electronic fuel pump years ago.
I also hear the fuel pump relay switch during the fuel pump initiation at key turn, then during crank I can hear/feel it switch back? Is this norm?
I do get spark with a spark plug test, I also get power at the injectors...
If I do get it to roll over its briefly after I left
the fuel pump prime a few times or with carb cleaner in the intake
I'm thinking fuel pump or relay arm... Any suggestions are welcomed , please , ha.
Old 04-20-2015, 09:19 AM
Camaro1969's Avatar
Could it be my vats? Maybe it just so happened to go out ?
Old 04-20-2015, 04:16 PM
did you test the injectors with a noid light to see if they were being told to fire?
Old 04-20-2015, 04:21 PM
oomfh
07-04-2011 08:17 PM
oomfh
12-15-2010 10:16 AM
jeremy62566
06-10-2009 04:20 PM
shiby4ever
02-15-2006 01:22 AM
rgviola
09-20-2005 05:01 PM
Quick Reply: 1993 won't start - fuel?
