**Smoking when on Full Throttle..??
Souns to me like worn valve seals. So yes burning oil. If i was you id remove oil then inspect it. Then measure to see if you are really low. My buddys z measure almost full and when we removed the oil it only had 2qts. That was an lt1
he said he changed his oil and then the problem started. Like i said ive had oil indicators lie to me more times than a politician
Car doesn't blow black smoke anymore.
