Inoperative handbrake?
Old 10-23-2012, 09:27 AM
Amy Z28's Avatar
Default Inoperative handbrake?
Hey my handbrake on my 86 camaro has never worked since ive owned it (4yrs) but this year the garage have decided to fail it! the cables look ok, its discs on the back does anyone have any pointers i can do myself before it goes back for mot? thanx
Old 10-23-2012, 11:00 AM
If your car has an automatic transmission, chances are good that your hand brake has never (or rarely) been used. What that inactivity can do is let your cable rust and lock itself to the casing. You need to first disconnect the cable in back and see if it moves freely, independent of the brakes.
Old 05-03-2013, 01:37 PM
microkid's Avatar
March 2011 ROTM
Technical User
also, the rear calipers have a tendancy to lock up from inactivity. they are the most complicated caliper i have ever seen. i replaced all the cables and the calipers on my car, and they were seized again in 4 years
Old 11-26-2013, 07:56 AM
redrelyt12's Avatar
Can you not pull the handle or does the handle move freely? I'm guessing either the cable has stretched out and you simply need to tighten the bolt, or I've heard of cables slipping off of where they're routed which causes them to not tighten also
Organgrinder010
04-01-2011 08:00 AM
oliverjohn
01-14-2009 09:25 PM
lowmileage
08-29-2008 08:01 AM
auscam
07-12-2005 02:34 PM
auscam
07-11-2005 12:37 AM
Quick Reply: Inoperative handbrake?
