rear end feels like it is twisting!!!!!!???????????
Old 02-18-2008, 04:58 PM
1986chevyc10man's Avatar
Default rear end feels like it is twisting!!!!!!???????????
wats up i have a 1992 camaro rs 5.0 when u take off hard the rear end feels like it is twisting i was wondering if the torque arm bar maybe the reason of the panhard bar the only does when u hammer on it any help would be great the vibration goes all the way back to the trans from the rear to trans thanks
Old 02-18-2008, 06:35 PM
Default RE: rear end feels like it is twisting!!!!!!???????????
The rearend connected to the torque arm...
The torque arm connected to the trans tail...
The trans tail connected to the trans mount...
The trans mount connected to the crossmember...
Check your transmission mount. If it's split apart, the torque from the rear will lift the tail of the trans and just cause trouble. If bad, replace it with a polyurethane mount.
89Camaro383
82-92 V8 Tech
12-03-2011 10:21 PM
osduck5
08-19-2010 04:58 PM
Antwan
02-23-2009 02:01 PM
ScottD
10-28-2008 11:02 PM
Quick Reply: rear end feels like it is twisting!!!!!!???????????
