Ignition Key Stuck
Ignition Key Stuck
Hey I have a 1992 Camero RS and can not get the key out of the ignition. I made sure the car is all the way in park and I have also even tried forcing the key to turn all the way back. Any ideas on what to do?
RE: Ignition Key Stuck
You are having all types of problems. First and most important. Camaro has 2 As' and no Es'.
Does your key not turn back all the way? There is a shifter interlock cable that comes from the shift lever to the ignition switch. Not the acctual lock itself but the switch located near the bottom of the column. The cable can be removed from the switch and it will work fine. It will be able to turn the key off while the car is in gear though. But I had to remove it when I installed a B&M shifter.
Operator head space? oh you were in the military! does,nt that have something to do with a technical term when disassembling a M-16 rifle? anyway the key issue, is the wheel tight to one side ? you know up against the wheel lock? try grabbing the wheel and turning it one way or the other, while trying to turn the key.
