Hei 350 timing? - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 11-18-2008, 09:53 PM
Location: IN, or hell whichever, wait, its too cold to be hell
Default Hei 350 timing?
I just installed this engine http://www.jegs.com/i/GM+Performance...353K2/10002/-1 with a jegs hei distributor but I am having trouble getting the right timing. Unfortunately I dont know at what degree to set the timing. right now it is at 6 and running pretty crappy. anyone else have an idea?
Old 11-19-2008, 12:11 AM
Default RE: Hei 350 timing?
i would start at 8 degrees and work my way up,but a mild motor like that shouldnt need more than that,i think i'm no expert at all just a shade tree mechanic
Old 11-19-2008, 02:17 AM
That is just a stock replacement. 6-8 should be fine for you. If its running crappy you may have some other issue.
Old 11-19-2008, 02:48 PM
I had to increase the timing just to keep it running, it was backfiring thru the carb and dying. I am going to try replacing all of the plugs and wires to see if it improves. I had the accel "do it yourself wires" and I didnt have crimpers just a pair of pliers. Stupid I know. thanks for the help. also one more question. My distributor has vacuum advance on it and I have it hooked into the carb on the recommended vaccum line. But I have heard others say not to listen to that and it works better if it is running off of manifold vaccum. does anyone know if this is tru and if I should switch it?
Old 11-19-2008, 06:41 PM
You may have your carbs RPM too high and its throwing off your timing. They both need some tweaks at the same time to find its happy place.
The vacuum advance should be hooked to the carb down by the butterflys but above them so it does not get manifold vacuum. There should be a provision on the carb for that.
Also double and triple checjk if you have to and make sure you have you fire order correct.
Old 11-30-2008, 09:44 PM
I finally got it all sorted out, or so it seems for now. just wanted to thank everyone for there help.
Old 11-30-2008, 10:19 PM
That is what we are here for. And to pick on ScottD
Reply
Thread Thread Starter Forum Replies Last Post
406 timing old hoon 67-69 V8 Tech 2 01-23-2014 12:51 PM
Timing with adjustable timing light ????'s ScottD 82-92 General 10 03-18-2010 01:36 AM
no timing 87 rag 82-92 V8 Tech 1 08-06-2008 12:49 AM
timing?? vabeachxj 82-92 V8 Tech 13 07-13-2008 11:59 AM
timing help 94z28chevy 82-92 General 2 07-03-2008 07:55 PM
Tags
350, attachments, camaro, chevy, distributor, fire, gm, hei, high, set, setting, timing, vaccume, vacuum, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
