Which Camshaft ?
Which Camshaft ?
Hi there ,
Looking at doing some mods in the future , currently running a 1987 350 TPI in my 1986 auto Z28 (Factory auto 305), I would like to fit an aftermarket camshaft thats going to make it a little more perky and above all that nice lumpy Idle .
I would like some info on what make / profile cams I should be looking at and if anyone would like to share there stories.
Also where does one look on both motor and trans to identify exactly what I'm running as car is not all original.
Thanks in advance
Thanks in advance
I used this utility when deciding which parts to buy for my engine.
CamQuest ? Select The Perfect Camshaft & Valve Train Components
I've got this cam, if I recall correctly.
http://www.summitracing.com/int/part...08-8/overview/
OE Camshaft specs: as a reference
1985 (L69 & LB9) Duration @ 50: 202/206 Lift (1.5): 403/415 LSA: 114.5
GM Part #14088843
1986 (LB9) Duration @ 50: 178/194 Lift (1.5): 350/385 LSA: 109.0
GM Part #14094097
1987 (LB9 5-Speed, L98) Duration @ 50: 202/207 Lift (1.5): 404/415 LSA: 114.5
GM Part #10088155
1988 & 89 (LB9 5 speed, L98) Duration @ 50: 207/213 Lift (1.5): 415/430 LSA: 117.0
GM Part #10066049
1990 (305 5-speed w/G92 & 350) Duration @ 50: 202/207 Lift (1.5): 413/428 LSA: 114.5
GM Part #10111773
GM Part #14088843
GM Part #14094097
GM Part #10088155
GM Part #10066049
GM Part #10111773
