Which Camshaft ?
Old 03-22-2015, 12:52 AM
IROC Downunder's Avatar
Default Which Camshaft ?
Hi there ,
Looking at doing some mods in the future , currently running a 1987 350 TPI in my 1986 auto Z28 (Factory auto 305), I would like to fit an aftermarket camshaft thats going to make it a little more perky and above all that nice lumpy Idle .
I would like some info on what make / profile cams I should be looking at and if anyone would like to share there stories.
Also where does one look on both motor and trans to identify exactly what I'm running as car is not all original.
Thanks in advance
Old 03-22-2015, 09:06 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
I used this utility when deciding which parts to buy for my engine.
CamQuest ? Select The Perfect Camshaft & Valve Train Components
I've got this cam, if I recall correctly.
http://www.summitracing.com/int/part...08-8/overview/
Old 03-23-2015, 11:29 AM
birdman11's Avatar
thats no bigger than stock, and the lift is too much, you would need to change your springs. Its really duration that matters. Look for something like a 210/216 but no bigger than a 220 duration@.50
Old 04-01-2015, 05:42 AM
Everett#2390's Avatar
OE Camshaft specs: as a reference
1985 (L69 & LB9) Duration @ 50: 202/206 Lift (1.5): 403/415 LSA: 114.5
GM Part #14088843
1986 (LB9) Duration @ 50: 178/194 Lift (1.5): 350/385 LSA: 109.0
GM Part #14094097
1987 (LB9 5-Speed, L98) Duration @ 50: 202/207 Lift (1.5): 404/415 LSA: 114.5
GM Part #10088155
1988 & 89 (LB9 5 speed, L98) Duration @ 50: 207/213 Lift (1.5): 415/430 LSA: 117.0
GM Part #10066049
1990 (305 5-speed w/G92 & 350) Duration @ 50: 202/207 Lift (1.5): 413/428 LSA: 114.5
GM Part #10111773
mrblock2013
82-92 V8 Tech
05-13-2012 01:19 AM
hatchetman1025
08-07-2008 01:05 PM
BoricuaHec01
04-22-2008 11:25 PM
crgm101
12-28-2007 09:08 PM
95camz28
11-16-2007 02:36 PM
Quick Reply: Which Camshaft ?
