5.3l ls based vortec in my camaro
Old 09-14-2006, 03:14 AM
1bad88's Avatar
Default 5.3l ls based vortec in my camaro
i also posted this in the engine page but this page may b better....i want to put a 5.3 vortec in my 88 wat do you guys think of this?? i have a newer silverado with the 5.3 in it i love the engine i have little mods done to it and for being in a fullsize truck its pritty quick and i was thinking of buying an engine from one n build it from ground up with a turbo set up and just doing all i can to it..also will i have to custom make mounts or does anyplace have mounts for a swap like this...ive already went from the 2.8 FI to my 355 but i want to do somthing diffrent and i havent seen one of these engines in anything like this...help me out give me some input any suggestions are wanted bad or good
Old 09-14-2006, 12:38 PM
355CAMARORS's Avatar
Default RE: 5.3l ls based vortec in my camaro
I FEEL YOUR THRILL. I ALSO THOUGHT OF DOING THAT SWAP. BUT YOU ALSO GOT TO TAKE INTO CONSIDERATION OF THE WIRING HARNESS. AND THAT THE ENGINE IS THROTTLE BY WIRE AND NOT BY COMPUTER. TRUST ME THIS SWAP HAS BEEN RUNNING THROUGH MY HEAD FOR ABOUT 5 YEARS WHEN CHEVY FIRST INTRODUCED THE 5.3. IT A GREAT AMOUT OF TORQUE AND THE RESPONSE IS AWESOME WHEN YOU MASH THE GAS.
Old 09-14-2006, 01:54 PM
AlfredB18's Avatar
ORIGINAL: 1bad88
I think thirdgen.org may have at least a couple of 3rd Gen LS1 swappers....I would recommend an early F-body wiring harness to go with the 5.3L, since that should be interchangeable and you can use a throttle cable on a 5.3L in that regard.
Why stop at a 5.3L, though? A 6.0L takes up the same space and is probably only marginally heavier.
Old 09-14-2006, 02:48 PM
81CanuckZ's Avatar
The 6.0 doesn't have the response of the 5.3. The 5.3 revs a lot nicer then the 6.0. We have a suburban with the 5.3 and it's awesome. Very smooth compared to the 6.0. We have 3 trucks at work with the 6.0. Go for the 5.3. It makes almost the same power and is much nicer. Just my opinion.
Old 09-14-2006, 04:13 PM
t4nk's Avatar
ORIGINAL: 81CanuckZ
+1..
the 6.0's are dogs compared to the 5.3
lol why stop at 6.0?! get the 8.0 big block in there! lol.. and the allison tranny!
Old 09-14-2006, 04:20 PM
81CanuckZ's Avatar
The 5.3 is a fantastic engine. Great power, torque, and response. They sound sweet too with a set of headers. Go for the 5.3...it's a much better engine.
Old 09-14-2006, 07:25 PM
1bad88's Avatar
yea i love my truck and i have never had a single problem with my 5.3 i have full exhaust n it soudes great i could only imagine wat it would sound like with a cam n just being worked to the ***** with the turbo set up id love to work the engine in my truck and start running that but i dont see the sense in doing that to a 4wd but ive really wanted to see the kinda power i can get out of one of these and i think puting one in my camaro would b the way to go..now being an ls based motor will most of the internals be about the same as an ls1...beacuse ive looked under 5.3 in many sites and cant find bigger pistons new rods or nething ive found cams rockers and heads and thats about it
Old 09-16-2006, 01:12 AM
81CanuckZ's Avatar
That's probably a good start. Keep looking ad stuff will turn out. Post your progress and keep us updated.
Old 09-16-2006, 01:25 PM
AlfredB18's Avatar
ORIGINAL: t4nk
ORIGINAL: 81CanuckZ
Really? Hmm, I'd have attributed that to maybe the fact that pretty much all 6.0L's are in HD GM trucks--not exactly race trucks. The 345HP engines in the Caddy trucks can't be all that doggish, could they?
+1..
Old 09-16-2006, 03:05 PM
81CanuckZ's Avatar
Th 6.0HO is much better than the normal 6.0, but i'd still go for the 5.3. It's just a better engine. I've heard that they can take more abuse, but don't quote me on that. If it was me i'd rather have the 5.3.
seegeer
09-22-2008 01:00 PM
stbowen
03-16-2007 01:25 PM
JOHNANDJEN
09-14-2006 04:44 PM
1bad88
09-13-2006 11:30 PM
Quick Reply: 5.3l ls based vortec in my camaro
