3rd Gen Motor/Trans swap?
Old 10-29-2013, 10:14 PM
Strickland84's Avatar
Default 3rd Gen Motor/Trans swap?
Hi I am thinking of buying a 3rd gen soon. I like the body style but I might like to have a bigger engine than the 305 with a manual trans. What do you guys suggest for a v8 and manual trans combo????? Is there a common swap that the Camaro guys do?
Old 10-30-2013, 08:05 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Your best bet is going to be a 350. It'll have the same exterior dimensions as the 305 and should bolt right in. However, the stock manual transmission is very weak- they broke under the stock 305. You'd be wise to either learn to love an auto, or buy a stronger transmission, too.
Unless you're doing all of the work yourself, expect the cost of the swap to far exceed the value of the car. I spent $10k going from a 305 to a 350.
Old 10-30-2013, 10:57 PM
What would you suggest for a transmission......would the drivetrain (engine and trans) from an early 4th gen (93-96) work, they have 350's with 6 speed manuals correct.
Old 10-31-2013, 06:42 AM
March 2010 ROTM
Tremec is a good brand. Anything from them that can handle the torque of your engine is a good bet.
If you've got a donor car, then an LT1 could be good. You're gonna need a lot more than just the engine and transmission. I've never done such a swap myself so I don't know all of the things you'd need, though.
Old 10-31-2013, 08:54 AM
Old 11-01-2013, 07:35 AM
drdave88's Avatar
The stock T5 manual trans will hold up depending on your driving style. The exact number is debated, but generally its only rated for about 300lb/ft of torque. If you don't plan on beating on it hard, it should hold up. There are a lot of people running T5's behind 350s, 383s, etc and they've survived for years.
Having said that, there are a lot of better options for transmissions out there (T56), if you have the money for it. T5 is good for a tight budget though.
Old 12-25-2013, 06:45 AM
draggo144's Avatar
I have a high performance 350 shifting through my T-5 and have had no issues yet *knock on wood* and I beat the hell out of the thing. My motor is putting a minimum of 350 HP to the ground. Car originally had a 305 TPI. However, being a '91 I have the World Class T-5, which was put in Camaro's from '90-'92. The have some different bearings in them, I believe, that aid in their ability to handle the power.
Your best bet is to upgrade to a 350. Very reasonable in price, and if you want to go ***** out you can stroke it later and put heads/nitrous on it to make a serious streeter.
Old 07-04-2014, 08:15 AM
Weldinchevys's Avatar
I have had many T5 transmissions behind 350s and my only issue would be the first year syncro would go out but was a very easy fix only had to be done once. Would deffinatly suggest it!!
bigfitchy11
04-28-2012 05:22 PM
423hycar
01-26-2010 04:36 PM
nebraska83Z28
10-26-2009 12:50 PM
djs383
82-92 V8 Tech
06-01-2009 10:38 AM
Quick Reply: 3rd Gen Motor/Trans swap?
