1990 Camaro RS
Old 10-31-2007, 10:16 PM
CCarRocks's Avatar
Default 1990 Camaro RS
For some reason the in dash tach goes all the way over to 7 grand even if I'm just cruising along at 20 MPH or driving down the road at 70. Sometimes it comes back over to a range in the lowe lines but any throttle input & away it goes.
What's up with that
CCarRocks
Old 11-03-2007, 09:46 PM
cjsuret's Avatar
Default RE: 1990 Camaro RS
No sugestions other than make sure your wire connectors are tight on the tranny,
Old 11-04-2007, 01:07 AM
Dougs1990rs's Avatar
your instrumant cluster is going out. mine does it with the speedo but mine stop's at 27 mph. it's expensive to get fixed. i would just get an after market tach.
Old 11-04-2007, 07:12 PM
CCarRocks's Avatar
The ole instrument cluster going out thing. Man what a bummer I guess now it's time to get an after market gage setup
Thanks for the input, I had no idea where or what could be going on. Hopefully the speedo is correct or I'll ge a ticket
CCarRocks
Old 11-04-2007, 08:00 PM
CCarRocks's Avatar
So the tach gets its signal from the transmission.The transwas rebuilt about 2 months ago according to the man I boughtthe carfrom. I'll get underneath & check them.
I thought the tach got its signal from the distributor.
Old 11-05-2007, 02:27 PM
Norris's Avatar
Is it a V6 or a 305?
Old 11-05-2007, 06:20 PM
CCarRocks's Avatar
It is a V6 car.
Which transmission should this have some with a 700R4 or ?
Old 11-05-2007, 09:48 PM
Norris's Avatar
You should have a 700R4 (a pretty lightweight version at least). Your tach signal should come from a cam or crank signal through the ign control module, possible through your computer, and then to your gauges. I'll check a schematic in the morning, unless somebody else has one.
Old 11-05-2007, 10:28 PM
PedalToMetal's Avatar
Had the exact same problem...
Old 11-06-2007, 02:26 AM
Gixxerkid's Avatar
my car idles wierd. It sits around 500, then jumps a little bit, and dies down to almost 100. How do I go about fixing it so it is always at a constant idle?
Quick Reply: 1990 Camaro RS
