It's Cherry Red HELP! - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 04-12-2009, 02:29 PM
Angry It's Cherry Red HELP!
Where the 3 pipes come off the block to the 1 Is glowing cherry red only on the drivers side it occurs after about 15 min of driving and causes smoke to enter the drivers side. It's severely bogging down the "performance" of the car giving me about a 0 - 60 in 2 - 3 min. I might be exagerating a bit but it is realllllly slow.
Old 04-12-2009, 04:45 PM
is the motor overheating? full of coolant? what does coolant and oil look like. color, oil in water, water in oil? what year, model? what does the exhaust sound like, quite, hissing, poping?
Old 04-12-2009, 04:55 PM
No the motor is not overheating, no water or coolant in the oil everything looks normal. It is the 2.8 RS Automatic '89. Exhaust sounds like there is a leak, like a hissing sound. When I was on the gas it sounded as if it was working too hard.
Old 04-12-2009, 04:58 PM
sounds like a plugged catalytic converter.
Old 04-12-2009, 05:02 PM
That's what me and my husband were leaning towards however would that only cause one HEADER to be glowing red. Because I assumed that both would be glowing, and there is exhaust passing through although minimal.\
Old 04-12-2009, 05:03 PM
dual exhaust? strange that only one is doing it. if not duel does it have a floppeer valve on crossover pipe on the exhaust.
Old 04-12-2009, 05:11 PM
not sure about an 89 but the old style motors used to have a valve that evens up the back pressure, they used to get stuck on us. i would guess that if it has a crossover like my 93 (does not have a flpr valve) and it crosses from the drivers side to the passanger side that the closest manifold to the cat would get the air flow.
It has a collector off of the headers before the catalytic conv., then runs back to a transverse muffler with two exhaust pipes. Being that it is a V6 the side that is glowing is the side that has a direct line to the converter. The ceramic gaskets between the actual headers and the downtube was cracked on one side but the side that was glowing was not.
Old 04-12-2009, 05:21 PM
could be that leak or crack let just enough air out to not get red.
Old 04-12-2009, 06:04 PM
Ok So then the next question is since this exhaust system seems to have been modified does anyone have a pic of the original exhaust system or a diagram.
Reply
Thread Thread Starter Forum Replies Last Post
got a cherry bomb 1998camarossclone 93-02 V6 Tech 9 12-22-2010 11:31 AM
cherry Bombs 73camaroSS Intake, Headers, and Exhaust 8 03-24-2008 08:15 PM
Cherry Bombs CamaroKid81 Intake, Headers, and Exhaust 6 09-18-2007 01:43 AM
no cat and cherry bomb ! Pro_built7 93-02 V6 Tech 10 05-15-2007 08:36 PM
My cherry Pop hardwire666 New Members Area 4 07-13-2006 06:34 PM
Tags
09, 69, 92, block, camaro, camero, cherry, chev, chevy, exhaust, manifold, red, small, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
