1989 camaro rs v6- cold fuel injector O ring
Old 04-13-2014, 01:33 PM
RdBlock's Avatar
Default 1989 camaro rs v6- cold fuel injector O ring
Hey has anyone had a problem with a fuel leak from the cold fuel injector? I took it apart and the O-ring is cracked the part is obsolete and im having a hard time locating one
Any ideas?
1989 camaro rs v6- cold fuel injector O ring-forumrunner_20140413_113318.jpg
Old 04-14-2014, 05:20 AM
Everett#2390's Avatar
Go to a local Hydraulic/pnuematic hose shop.
Take yours with you for them to compare.
Use petro jelly (Vaseline) for lube on installation.
O-rings go by wire diameter - dia of the ring, amterial, generally Buna-N,
ID and OD as back-up.
Old 04-14-2014, 09:59 AM
More correctly referred to as a cold start "valve". It's not a fuel "injector" as we know fuel injectors.
AC Delco part # 17111954 is the 3 ring seal kit. Pick a vendor, any vendor: Cold Start Valve Seal Kit
Kendagenius
02-05-2017 12:23 PM
pimpjuicepd
04-02-2011 04:27 PM
microkid
09-02-2010 08:40 PM
XReply
08-16-2008 03:40 PM
johnson3034
05-25-2007 09:35 PM
Quick Reply: 1989 camaro rs v6- cold fuel injector O ring
