vacumn canister
If you have the original trans, it's a 700R4 and it's not vacuum controlled. Or did somebody swap in something different like a T350, which is vacuum controlled. Even so, with those you don't add a vacuum canister between the carb and trans to alter the shift points, there are other ways. So, what trans do you have?
