would subs over the rear end help traction?
Old 09-22-2013, 03:29 PM
slayer13x's Avatar
Default would subs over the rear end help traction?
im big on good quality audio so im going to be putting a full range soundsystem in my camaro. but i want to know if mounting the subs in the caved down part of the trunk and the amp over the axle will help with rear grip,lifting the front end or weight distribution?
Old 09-23-2013, 12:29 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Realistically, a sub won't make much difference. If you want to improve grip, buy some new tires, new shocks, sub-frame connectors or any other type of body stiffening device. Any of those will make a bigger difference than a subwoofer.
A good set of BFG gForce Super Sports will run you around $600. I run them on my IROC, and they're fantastic.
Old 08-10-2014, 12:38 AM
3rdGenHitman's Avatar
ya technically speaking it WOULD help, but not even a noticeable amount. like previously said your best bet is tires.
camie
07-21-2019 11:07 AM
cortes202
06-07-2012 10:02 PM
Gorn
07-02-2010 09:15 PM
red star
12-06-2007 07:14 AM
jbe123
10-24-2007 07:24 PM
Quick Reply: would subs over the rear end help traction?
