New rear suspension install
Old 05-23-2015, 08:26 AM
IROC87's Avatar
Default New rear suspension install
Founders Performance lower control arms with 3 piece rotor bushings, adjustable panhard bar, greaseable poly swaybar bushings, poly end links and Moog IROC replacement springs. Anything else I need to buy before I start the install?
Old 05-23-2015, 09:08 AM
refreshments.
Old 05-23-2015, 11:34 PM
MKCoconuts's Avatar
Shocks too.
Old 05-24-2015, 08:09 AM
blackz87's Avatar
My first choice would be Sub Frame Connectors (SFC) and Shocks the rest is not going to help you.
Old 05-24-2015, 02:45 PM
IROC87's Avatar
Will be getting weld in sub frame connectors and Koni yellows. Just installing the parts I already have.
I do need to take a trip to the store for refreshments!
Old 05-29-2015, 10:50 PM
IROC87's Avatar
Ordered the UMI subframe connectors tonight.
Old 05-30-2015, 07:52 AM
blackz87's Avatar
After you install th welded in SFC's, you will feel the difference right away. SFC's should be the first mod made on any 3rd gen models.
Old 11-26-2015, 03:21 PM
Hell Jes's Avatar
Ok, what should be the second and the third?
Old 11-27-2015, 07:42 AM
blackz87's Avatar
1) Front struts & Rear shocks
2) Front & Rear sway bar bushings and end links
Now with the above and the SFC's you should have tight and good handling car.
Old 12-03-2015, 03:21 AM
Hell Jes's Avatar
Thanks for your reply. Is there a good brand in those things? I want to go for cost effectiveness because I have to have them shipped overseas...
Quick Reply: New rear suspension install
