Temp Gauge/Cluster bad (1986 z28)
Old 04-24-2014, 10:27 AM
polinder_88's Avatar
Default Temp Gauge/Cluster bad (1986 z28)
I have an 1986 Z28 that has a non functioning temp gauge in the cluster. I was told that the cluster itself is bad by a mechanic. Has anyone replaced the cluster with an aftermarket?
is it worth it to upgrade to a digital cluster?
or should i just have them "rebuild" the current cluster?
thoughts please
Old 04-24-2014, 04:02 PM
blackz87's Avatar
Do the other gages work??? If they are ok, try replacing the temp sensor in the driver's side head. I had my go bad and that is all it needed to make the temp gage to work.
Old 04-25-2014, 08:03 AM
all other gages work. i will try your advice. thanks
Old 09-14-2016, 12:08 AM
(mike)'s Avatar
Classic industries sells brand new temperature gages for 82-89 Camaros. I bought one and installed it in my 87 and it worked great. I think it was $50. Fairly easy install. it just plugs into the cluster.
Old 09-14-2016, 12:09 AM
(mike)'s Avatar
Didn't notice this post was so old. sorry
Mitch Upton
67-69 V8 Tech
09-09-2011 04:04 PM
josh95camaro
10-09-2009 10:15 AM
vzfox
11-10-2007 10:05 PM
Corr182
03-28-2007 03:36 AM
Quick Reply: Temp Gauge/Cluster bad (1986 z28)
