please help!!!!!!
Old 02-20-2017, 12:44 PM
marlonag's Avatar
Default please help!!!!!!
Hey i have a 97 chevy camaro. Definitely needs work done. Right im trying to figure out why my radio wont come on anymore, why the button that opens my rear latch wont work and why my the digital part on my mileage wont work suddenly. i replaced the fuses for those things but still not working. Anyone know what it could be.
Old 02-20-2017, 04:37 PM
hay marion welcome to the forum. wow thats a weird one. wonder if maybe its the bcm. i know it can mess with the radio. dont remember it messing with the other problems you have though. i moved your thread to the 4th gen general section for you.
Old 02-20-2017, 04:56 PM
looks like some of those things may go through the bcm in a 97. stereo goes through the rap but it goes into the bcm. probly be a good idea to check for power at the switch for the hatch to make sure its not in the wiring or a bad hatch release. the milage counter is not on the schematic i was looking at.
http://shbox.com/1/bcm_1996.jpg
http://shbox.com/1/rap_schematic.jpg
check out shbox, good info 4th Gen LT1 F-Body Tech Aids
Old 02-21-2017, 12:56 AM
peterpar's Avatar
The rear hatch release switch provides a path to ground to the BCM. Check continuity to ground on both sides of switch to verify the switch operation. You might also want to check the power accy fuse #7 in the IP fuse block. This circuit provides a power feed to the BCM, Rear Hatch Release Relay, Radio and the security indicator on the instrument cluster. This is all I can find that are common to most of the problems listed. Possible that some are separate occurrences. I've attached a few schematics from the 1998 manual that may help. I believe they should be the same as 1997.
File Type: pdf
bayboyss
01-07-2009 06:14 PM
thebandit110
10-26-2007 05:02 PM
vettman81
01-24-2006 12:03 AM
Quick Reply: please help!!!!!!
