won't start after driving for 15-20 min.
Need help i bought an 89 camaro RS V6 2.8 after i drive it for a little bit it won't start up. When i turn the key it does do anything. I can hook jumper cables to it and it fires right up. Had the battery. And alternator checked and was told they are fine. Any help would be appreciated. Thanks
Yes it can. Did you check to see that you have no spark when that happens? First thing I would suspect is the coil, only because I've had it happen on a couple of vehicles. Other people's results may vary. Another possibility is the ignition module inside the distributor. The coil would be my prime suspect though.
let's catch our breath and plz bear with me as I do not know the history and only know what i can read in the thread
car starts
when hot, car won't start
let cool down, car starts
battery has been replaced with a brand spanking new battery, correct?
when hot, using jumper cables connected to another car, your car will start
question: is it a manny tranny? If so, when hot, have you ever tried putting the key to "run" and then getting the car up to about 5 mph and popping the clutch in 2nd gear? Does it start? (be sure to put the clutch back in or it will stall)
If auto tranny, does the starter sound labored when hot and when adding the 2nd source of energy it cranks faster?
wanna guess where I'm heading with this?
What does that statement mean? Did you mean "it doesn't do anything"?
If so, do you mean the starter does not crank the engine? If that is the case, do you hear a click at the starter?
