Wiring Problem
Old 06-13-2007, 11:25 AM
maddoghowe's Avatar
Default Wiring Problem
i just recently bought a '91 Z-28 there was a problem with the system draining batteries, with a new alternator and battery installed, we fixed a loose ignition wire on the starter to take care of that, now while driving the guages will suddenly burry themselves and quit working and the engine will run rough, then it will smooth out and run fine with the guages working correctly also, and back and forth. just now it is staying messed up, doesn't seem to be going back and forth. any suggestions? i'm figuring bad ground somewhere, but there are so many
BillsFan727
06-26-2012 12:48 AM
Corby Seitles
02-17-2012 09:02 AM
GetUpTop
04-21-2009 07:34 PM
chris n
67-69 V8 Tech
11-30-2008 09:47 PM
inky21
10-20-2007 02:50 AM
Quick Reply: Wiring Problem
