I am looking at some torque thrust 2's, two front 15x8s with bfgoodrich radial TA's 235s. and 2 15x10s with 295 radial TA's. Will these fit without any adapters/spacerS?
Thanks
__________________
85 Trans Am
http://www.cardomain.com/ride/2393803
But they will fit? Do you think it would look bad? it looks like a pretty good deal, the set of torque thrust 2s and the set of tires w/ 100 mils on them for about $550 shipped
__________________
85 Trans Am
the fronts will fit no problem, iroc rims are 16x8 all around, the only thing i'd be concerned about it the 10's on the back, worst case i guess you buy some spacers for the rear, and like 74454bb said, the backs will probably stick out of the wheel well, wont make it look bad, but it'll be hell on your paint.
__________________
Theres no replacement for displacement
-1986 Camaro Sport coupe
-a goodies list as tall as you
jump on the deal, if you dont like them you will have no problem gettin your money back. As far as looks I havn't seen anything look bad with those on it.
The rims may stick out a bit in the back, you may have to get some mud flaps to keep the rocks and dirt from chipping, as far as the spacers ,shouldn't need them I think the backspace on those is still 3 3/4. Your car will look faster.
