vacuum lines - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 04-25-2009, 10:58 AM
Default vacuum lines
on my 84 z28, I am looking to clean up and get rid of alot of that emissions junk. anyone got a or know of a vacuum diagram for that so I can see what i can remove and cap off? Thanks
Old 04-26-2009, 04:23 AM
well, I just pulled a bunch of stuff off my 84 and its still running. I pullled the ac and air pump and pulled all the air tubes and blocked the cat air inlet so this is what I encountered.
there are no vac lines to the ac, but there is one under it. I say this cause there was a bad leak there that I would not have found without removing the ac. compressor.
on the front of the carb at the bottom on the driver side is a small vac line. pull that one and plug it at the carb. then follow that line and remove from whatever it connects to. it will go to a splitter thats mounted on the coolant in " CAP " ( top of manafold) its kind of a splitter for the vac and you can leave both open. that will take you to the air cleaner and the air pump and from there you should be able to figure all that out. I just removed the air pump as well and pulled all the tubes to the headers. my car runs MUCH better now and I think its cause there were many vac leaks. I have not done the egr valve yet bcause I dont have a replacement manifold yet, and I have not gotten any check engine lites yet. it took me about 5 hrs to do all this.
my 84 is a 305
Old 04-26-2009, 09:47 PM
On The Tree
Default 91
How bad will the egr valve being bad make the car run?
Old 04-26-2009, 11:45 PM
I dont know mine is still working ( its hoked up anyway) and so far the car runs better then b4
Reply
Thread Thread Starter Forum Replies Last Post
vacuum lines Patrick Quentin Musick 93-02 General 11 02-21-2013 01:39 AM
Vacuum Lines/EGR Corbin Durek 82-92 General 7 12-20-2012 11:40 AM
Vacuum Lines chrshadil LT1/LT4 Tech 1 08-07-2007 10:50 AM
Vacuum Lines? jdubs1813 General Tech 5 05-25-2007 05:33 PM
Need Help Vacuum Lines 73 T Top General Tech 2 05-01-2007 09:20 PM
Tags
1984, 305, 350, 3rd, 86, 91, camaro, chevy, diagram, gen, hoses, line, lines, vaccum, vacuum, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
