She feels a little loose.....
Old 08-09-2008, 02:21 PM
ScottD's Avatar
Default She feels a little loose.....
My front end sways when Im hammering it thru corners.Say Im going right, she will lean left and I gotta pull her back in again. It gets downright scary at high speeds. Struts are new, so Im thinking maybe coil springs? Any suggetions? I wish I could post a better description but I my posts are still getting bounced!
Old 08-09-2008, 02:27 PM
350rs's Avatar
March 2008 ROTM
Default RE: She feels a little loose.....
all of ours are man. have you tried subframe connectors? those help A LOT!!
Old 08-09-2008, 03:38 PM
MadMikeZ28's Avatar
Springs could be fatigued. Though the ones in my 84 were solid but it had low miles. Tire pressure and front end alignment.
Old 08-09-2008, 11:53 PM
Check your front sway bar and make sure yourend links are good.
Old 08-11-2008, 12:38 AM
Camaro_Boi69's Avatar
i would check your sway bars and sway bar links.
i had the same problem but it was in the back and it was from drifting a lil on the fast side.
bracket broke that held swaybar links to the body.
Old 08-11-2008, 12:37 PM
age84's Avatar
March '09 ROTM
Have you done any mod's on the suspension at all.
Hubbs
2010+ V8 Tech
03-11-2017 02:02 PM
89Camaro383
82-92 V8 Tech
12-03-2011 10:21 PM
osduck5
08-19-2010 04:58 PM
ScottD
09-29-2009 10:44 AM
ScottD
10-28-2008 11:02 PM
Quick Reply: She feels a little loose.....
