ROUGH IDLE
ROUGH IDLE
HEY GUYS WHATS UP I M NEW TO THE CAMARO FAMILY FORMALLY A MUSTANG DRIVER. I BOUGHT AN 86 I ROC AND IT RUNS REALLY ROUGH IT IDLES TO HIGH OR IT JUST BOGS DOWN WHEN I EXELLARATE. IVE CHANGED OUT THE COOLANT SENSOR, CHANGED THE SENSOR NEXT TO IT & RAN SOME SEA FOAM TROUGH THE SYSTEM AND NO LUCK AS FAR AS I CAN SEE THE CAR HAS 24LB ACCEL INJECTORS. I READ THAT CLEANING THE THROTTLE BODY HELPS WITH THIS BUT I DONT KNOW IF IT WILL PLEASE HELP AS I WANT TO BE ABLE TO GET HER GOING.. THANKS IN ADVANCE....
RE: ROUGH IDLE
THANKS FOR THE REPLYZ28 PETE I DID AND I FOUND THAT THE THROTTLE BODY WAS DIRTY *** HELL CLEANED IT OUT WITH A COUPLE OF BOTTLES AND THERE ROUGH IDLES GONE AND I ALSO CHANGED THE 5/8 VACUM HOSE TO TE PASSENGER SIDE OF THE CAR AS IT WAS BROKEN REALLY BAD.
