Replace Ignition Switch on a !986 Z26
Old 07-18-2005, 04:20 PM
RieskeKR's Avatar
Default Replace Ignition Switch on a !986 Z26
I have a 1986 Camaro Z28 with Vin. H 5.0L engine and 5-speed manual transmission. Voltage is not being supplied to the A/C fuse. Therefore, I suspect it is a faulty ignition switch.
I understand the ignition switch is located on the lower part of the steering column according to my Chilton's Repair Manual. The book says the steering column must be "lowered." The adjustment is explained as turning the key counterclockwise to ACC and turning the key clockwise two dedents. All of this sounds OK.
But are there any finer detail instructions on "lowering" the steering column to gain access to the ignition switch. Comments from someone who has performed this procedure would be greatly appreciated.
Kent
Old 07-18-2005, 06:55 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Replace Ignition Switch on a !986 Z26
its not really that easy IMO, i replaced my whole ignition system in my 89 RS, and it was a pain to get to that switch
JohnnyCars
07-23-2014 01:27 PM
NOLAcamaro
03-05-2012 08:28 AM
evilmnky45
07-31-2011 05:24 PM
Wyo77camaro
11-21-2009 03:22 PM
rayden7157
09-26-2007 12:10 AM
Quick Reply: Replace Ignition Switch on a !986 Z26
