Skip White Aluminum Throttle Bracket
Old 10-26-2010, 02:31 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Skip White Aluminum Throttle Bracket
Here's another thread on one of Skip White's products. This one is for his aluminum throttle cable bracket and stainless throttle cable.
I went with the two tone red and blue bracket, however he also has a blue and polished version available at the same price.
Throttle bracket:
http://cgi.ebay.com/ebaymotors/THROT...Q5fAccessories
Throttle cable:
http://cgi.ebay.com/ebaymotors/24-IN...Q5fAccessories
The bracket setup retails for $27.50 plus shipping, and the cable goes for $18.50 plus shipping. Each are priced less than half of the bigger brands like Transdapt, Lokar, and Jegs.
My initial impression of the bracket is so/so. Fitment is perfect with my Holley Street Avenger and Weiand Stealth intake manifold. The included mini nuts are a very nice touch. Everything assembles well with the included stainless steel hardware and the bracket functions exactly as it should. This is a HUGE step up from the Spectre brand chrome steel throttle bracket I was previously running.
I was slightly disappointed with the powder coat finish on the bracket. The colors are a little off from the colors you would find on your anodized fittings. With that said I believe an anodized finish would be much better suited to this product.
However, for the price I'm not complaining in the least. The bracket does exactly as its supposed to and still looks good sitting on top of the intake.
I know many of you are wondering if the bracket is compatible with the 700R4's TV cable. The kit does not come with the proper adapter to be a direct bolt on with a 700R4, however you can easily modify it to work. I used the adapter for the stock GM throttle cable and enlarged the opening with a Dremel. This allowed for the stock style TV cable to be securely fastened to the bottom of the throttle bracket. If you plan on using your stock throttle cable and not Skip's cable (or another aftermarket cable), this solution does not apply to you.
Another option is to purchase the correct TV cable adapter from Jegs or Summit.
As far as the stainless steel throttle cable goes, it appears to be a high quality replacement for your aged, melted, or torn up stock GM cable.
One of my biggest concerns was whether or not the bracket would work with a drop base air filter. My 14x3" Holley filter fits very well with absolutely no clearance issues.
I would definitely recommend this setup to someone who wants a more attractive and secure way to harness their throttle, but can't justify the $100+ for a name brand setup.
Here's some more pictures:
Old 10-26-2010, 02:46 PM
Pretty slick, and not a bad price either. Those colors don't float my boat though, I'd be opting for the polished version.
Old 10-26-2010, 02:58 PM
August 2009 ROTM
Exactly, that's my biggest gripe about the piece. I may paint it or have it powder coated black. Only problem with having it powder coated is that it will quickly make up the price difference between this piece and a more expensive one, although I can't imagine it costing more than $10-$20 bucks to have it powder coated.
Old 10-26-2010, 03:08 PM
My first impression when looking at it was, what's with the bluebird egg blue? Yuk!
Old 10-26-2010, 09:21 PM
August 2009 ROTM
It's a little darker than the pictures show, but I'm definitely not thrilled with it the color. I can live with it though. I will try contacting Skip to see if they can maybe change them up a little bit.
B_Dubya
09-23-2014 11:01 AM
Sedan2Camaro
04-10-2013 11:27 AM
mrayj88
11-22-2010 04:19 PM
Jr. Mechanic
06-22-2010 01:37 PM
skifast87
LS Series Tech
06-22-2006 05:26 AM
Quick Reply: Skip White Aluminum Throttle Bracket
