Leaking Gasoline
Old 10-21-2015, 07:44 PM
Everett#2390's Avatar
See if filler tube is flat by removing cap,
find a flat plate - lexan, steel, alum, etc, - and cover plate with emery paper or 1500 to 2000 grit sandpaper, and sand the tube barely.
You are trying to find a brighten area about the tube with no dark spots about the circumference.
Not flat, leaks.
Another suggestion, check tank venting to canister.
No venting, pressure build-up in tank due to road heat and could push fuel out the cap from fuel trapped in tube.
Katzen
05-27-2011 11:39 AM
SYDEWAYZSS
10-05-2007 04:35 PM
00camaro00
LS Series Tech
11-28-2006 10:16 AM
johnjr
04-04-2006 10:23 PM
Quick Reply: Leaking Gasoline
