Leaking Gasoline
Old 09-18-2015, 11:37 AM
B_Dubya's Avatar
Default Leaking Gasoline
1990 Camaro RS 305 TBI
I have a leaking problem with my gas tank. Every time the tank is full and i take a right turn at 10 mphs + i leak gas out of the cap.
The cap is very hard to screw on, I also think it could be bent.. when ilook in the filler tube, the grooves look a little scraped up, like the cap gets caught on it, maybe i just need to try and squeeze the tube and get it back to roun instead of oval.
I've replaced the cap 3 times.
Any other ideas? maybe i should sand the grooves,
Old 09-18-2015, 12:18 PM
Sounds like you're saying the filler tube up top is out of round, oval shape? If that's the case, then your cap likely is getting stuck and not going on all the way and sealing. Fix the filler tube so the cap goes on like it should. What got it out of round?
Old 09-21-2015, 04:51 PM
B_Dubya's Avatar
I have no clue to be honest, i know someone replaced the fuel pump for me once and removed the tank and cleaned it out... not sure as to why it leaks, i believe it leaked even beofre that incident.
Old 09-23-2015, 09:29 AM
Everett#2390's Avatar
Originally Posted by B_Dubya
Any other ideas?
Don't make right turns
If right turns are made, go less than 10 mph.
Seriously, yes, check filler tube for flatness
Might even smear some petroleum jelly onto the rubber seal of the cap and see if this lessens leakage.
Old 09-26-2015, 02:23 PM
B_Dubya's Avatar
Ya i'm going to check that today.
as far as petroleum jelly goes, do you recommend a specific brand and does it just say petroleum jelly? i've never used petroleum jelly for anything before.
Old 09-26-2015, 11:18 PM
Vaseline is petroleum jelly, all drug stores sell it.
Old 10-01-2015, 12:50 PM
B_Dubya's Avatar
Thank you very much! will do!
Old 10-01-2015, 01:01 PM
I believe most dealership parts counters have an open jar of Vaseline always at the ready too! lol
Old 10-09-2015, 07:07 PM
B_Dubya's Avatar
hahaha,
Well first i tried to tighten the neck up, no dice.
Then I tried the vasoline to see if it would screw in further, again no dice.
So then I got an idea!!!
I noticed the gas cap has a rubber gasket on it.
So i bought another gas cap... took the gasket off of it, put it on the one i was already using.. so now my current gas cap has two gaskets.. AND NO GAS LEAK!!
Now i can finally find out what kind of mileage i'm getting!
Old 10-21-2015, 03:02 PM
B_Dubya's Avatar
Well, I thought i fixed the problem by putting the second gasket on there... However... i can still smell gas... zzzzz
I thought i fixed it because I no longer see gas leaking on my rear quarter panel.
But when i go and feel under my gas cap... it's wet with gasoline...
I've tried to bend the filler neck with big pliers, but nothing seems to fix this...
Dare I try 3 gas cap gaskets??? ><
Quick Reply: Leaking Gasoline
