Idles rough
Idles rough
My 85 2.8 V6 is idling really rough, and now the check engine light is comming on. I have a pretty good idea that it is the fuel to air ration sensors, but I am not sure. Is there anything else that could be wrong?
RE: Idles rough
Well I took it in today....... and I was right it was the TPS and now I have to get that replaced, and I also need a new alernater but I can do that myself. Do you know if its easy to do the TPS yourself, or should you have a proffessional do it?
RE: Idles rough
I am assuming this is carburated. The TPS is in your carb. you'll need torx driver and a little mechanical ability because of the linkages. I would sugest replacing your alt and clearing the code then check to see if it comes back. Early computers as well as OBDII can give you false codes.
The Emperor
82-92 V6 Tech
11
09-16-2013 06:30 PM
