fuel pump relay location
Old 06-20-2006, 05:54 AM
sewerrat's Avatar
Default fuel pump relay location
Please help, I have an 88 camaro 2.8 V6. Can anyone tell me the location and description of the fuel pump relay? My Haynes repair manual doesn't show its location. Also, is it normal for the fuel pump to run a few seconds after the engine is turned off?Thanks
Old 06-20-2006, 03:49 PM
Default RE: fuel pump relay location
The relay shold be in the fuse box in the engine compartment. The location should be shown inside the cover of the box. Otherwise, open the hood, have some one put the ignition key to the on position and listen for the relay click on & off.
Old 06-20-2006, 07:00 PM
SickSickSick's Avatar
hmmmmmmmmm i don't like questioning you pete because i'm usually wrong LMAO but, none of my third gens have a fuse box in the engine compartment. all the relays are bolted to the firewall? sick
Old 06-20-2006, 11:56 PM
Sick, I belive you are right. I haven't messed with a third gen in quite a while, and I just assumed they were set up just like the 4th gen. And Sewerrat, sorry to lead you down the garden path.
Old 06-21-2006, 01:04 AM
thecamarokid's Avatar
the relay should be located on the firewall on the driver side inside a little plastic box looking thing without a top, at least that is where it is on my 91'
Old 06-24-2006, 05:51 AM
sewerrat's Avatar
no probs Pete, I actually found the relay using your suggestion. later I did find its location in the Haynes after reading better. And Sick and Camkid your right, it's on the drivers firewall next to the fan relay. Thanks again gents.
thetal1
09-29-2011 03:51 AM
tvscamaro
10-18-2008 10:16 PM
buckfever
12-27-2007 03:15 PM
Gordon24Camaro
10-18-2007 07:06 PM
7tstang
03-11-2007 02:10 PM
Quick Reply: fuel pump relay location
