firing order need help
RE: firing order need help
Well your looking in a haynes and that is why you are lost.
Start at the electrical wires going into the dist. Go clockwise to the first hold down bolt and the terminal after is #1. It should be the one bolt facing forward.
1-8-4-3-6-5-7-2
1-8-4-3-6-5-7-2
CHILTONS!!!!!
I'm gonna put this link in my signature from now on, and just point down, but here it is for you one more time:
http://www.partsamerica.com/ProductD...pe=626&ptset=A
Mike, As You know, You can make any point on the cap #1 and then continue firing order from there clockwise ( on a Chevy ) so as long as You have #1 corresponding to #1 ( rotor, cap, wire and plug ) and follow the 1-8-4-3-6-5-7-2 clockwise firing order, It will work. ............just a comment.
