How to make my v6 189 a bit faster.
Old 03-27-2011, 03:14 PM
Drexg's Avatar
Default How to make my v6 189 a bit faster.
Hello Camaro enthusiast! =D Well here's the thing I bought a v6 Camaro RS 3.1 and I'm at the point of fixing it up. But I want it to be a bit faster I don't want to do a engine swap yet I want just basics like intake headers full exhaust am I missing anything?:-)
Old 03-27-2011, 07:36 PM
microkid's Avatar
March 2011 ROTM
Technical User
good luck if you can find any. but yes, those would be starting points.
Old 03-28-2011, 07:46 AM
torque_is_good's Avatar
microkid isn't being a wise guy
Firast, your car is aged so it's stock performance has degraded. By how much, who knows but 10% is a very conservative number. So let's baseline your car at about 125HP. Torque maybe 165 foot pounds and those are flywheel numbers.
So let's be liberal and allow you 15% gains doing bolt ons. That brings your HP to low 140's and torque to about 190 ft pounds.
How much $$ and effort would be involved? You also would barely feel it.
Here's a thought, change your spark plugs, cap and rotor, use premium fuel instead of the 87 and advance your timing 2-4 degrees. For about $2 per week (20 cents per gallon x 10 gallons) and you will have a little more performance by advancing the timing.
I'm going to try and jump into your head for a moment which is't hard to do because just read most v6 disciussions on any auto forum
You bought a car that looks like a high performanmce vehicle but bought the sixer and tried to convince yourself that you'd be OK (when you're older it's ok but as a kid you have testosterone). Or, the vehicle was given to you and that's why you have a sixer.
If you want the performance of the 8, don't spend money on bolt ons, don't ask about forced induction etc. Clean it up, fix the interior, and sell it.
Yes, there are perfomance sixers out there like Porsche, 350/370Z, new Camaro, new stangs etc but they are modern technology.
Old 03-28-2011, 12:19 PM
carguy68ssrs's Avatar
BIG BIG FOGGER SYSTEM, It will be fast for a little while, then just put in a v8 when its done
Old 03-28-2011, 07:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
also, from what i have heard here, the 3.1 bottom end has a tendancy to break when any sort of performance work is added.
Old 03-28-2011, 09:43 PM
ScottD's Avatar
A K&N air filter, exhaust tip and crossfire sparkplugs will add at least 100 RWHP.
8*)
Sorry bub, you are SOL. Any kind of bolt on mod that you do is only going to yield a 2-5% gain, which I promise you wont even feel. If it makes you feel any better, that 3.1 is only marginally less powerful than a base 305 (V8).
Old 03-30-2011, 02:45 PM
Drexg's Avatar
Thanks everyone I think I might start of with headers. Then get a down pipe. Then maybe a k&N filter, but first a good tune up. And another question its got high mileage at 202xxxxxx what can I do to keep the engine running for a good while before I have the money to swap for a 350
Old 03-30-2011, 03:03 PM
Buffalo02Z28's Avatar
I say just drive the car, keep it running, do no performance mods and save up for the 350 swap. That V6 is just not worth pouring money into.
Old 03-30-2011, 08:04 PM
microkid's Avatar
March 2011 ROTM
Technical User
i for once will agree with buffalo. but to add to it, the cost involved with swapping a v6 to v8 car might be as expensive as buying one that is already a v8 car. the transmission isnt interchangeable between the 6 and 8, as well as a few other componants that arent cheap either
Old 03-30-2011, 10:54 PM
For once, I will agree with Micro. If you're going to go through the trouble of performing the V8 swap, you might as well sell your car and get a Z28 or an IROC-Z.
Quick Reply: How to make my v6 189 a bit faster.
