Cooling fan problem...
Old 04-18-2006, 07:50 PM
92camsilboat's Avatar
Default Cooling fan problem...
92 RS, 3.1, single cooling fan and temperature gauge. Someone before me rigged the cooling fan to run as soon as you to the key on. I pulled out the relay for the fan, disconnected the rigging job they did and reconnected it back to the original wiring. Results were no cooling fan kicking on at all, car reached over 220. Replaced relay and temperature sending unit and checked the fuse in the fuse block, stil nothing. Does anyone see something that im missing here????
Old 04-18-2006, 08:11 PM
coolcat's Avatar
Default RE: Cooling fan problem...
i kind of had the same problem, i changed the thermostat on it maybe yours might need a check
Old 04-18-2006, 08:22 PM
But it always ran at 160 on the gauge befor i hooked it back up to the original wiring. And the fan works, i do know that.
Old 04-18-2006, 08:24 PM
coolcat's Avatar
turn the engine on and let it get hot, you said it turned on at 160? Then when it reaches 160 feel the radiator hose is it hard or is it flimsy?
Old 04-18-2006, 11:05 PM
SickSickSick's Avatar
Might Wanna Check The Coolant Temp Sensor. Sick
Old 04-30-2006, 10:04 PM
Ok, I have replaced the thermostat, temp sensor on the block (driverside front), new relay. I did check and there is power getting to the relay. The car gets to 195, thermostat opens and cools down but the fan never kicks on. Is there another sensor to check? The car already runs a lot better now that is getting up to 195. But the fan still doesnt kick on and the temp did get up past 220.... WTF??
Old 04-30-2006, 10:11 PM
Well ... Now You Understand Why They Hot Wired It Huh? LOL The Only Thing I Can Figure Is Maybe There Is A Burnt Or Naked Wire Somewhere Causing The Sensor To Malfunction. Good Luck. Sick
Chevy101
06-29-2010 07:59 AM
gville4life
04-07-2010 11:27 AM
heath3800
01-09-2010 10:59 AM
mr porky
82-92 V6 Tech
09-15-2007 06:27 PM
02blackonblack
08-16-2007 04:01 PM
Quick Reply: Cooling fan problem...
