Center Link
Old 03-02-2015, 07:16 PM
B_Dubya's Avatar
Default Center Link
To replace the center link... i jsut have to measure the old link and make sure it is the identical length as the original link correct?
It's simple removal and replace correct? I just remove the link only from the arms, and then just replace it right back on there right?
Old 03-27-2015, 02:12 PM
B_Dubya's Avatar
BUUUUMP...
I need help with this. My mechanic wants to charge me $500 to replace the center link and ball joint.
I'm pretty sure i can do the ball joint, however... the center link looks a bit troublesome. Any links or help/advice would be greatly appreciated.
Old 04-12-2015, 05:36 PM
IROC87's Avatar
If you can take it off you can put it back on. Get a manual, also check on you tube for how to videos. Might make you feel better about doing it yourself. Just ordered all the parts to do mine.
Maniak907
06-30-2016 05:40 AM
briang573
10-23-2013 09:34 PM
TomBigBlock
03-30-2010 07:36 PM
bazkook
05-28-2007 11:25 PM
tylersilva12
06-23-2006 02:04 PM
Quick Reply: Center Link
