camaro berlinetta
camaro berlinetta
I have purchaced a 1984 camaro berlinetta and it hasno drivetrain or rear end, i am going todo an LT1 swap from a 1995 camarodrivetrain and was wondering what suspention parts i would need and what i would need to modify if anything thanks
RE: camaro berlinetta
you'll need an iroc suspension (spring shocks struts), also get weld in sub-frame connectors to reduce chassis flex, also some aftermarket trialing arms, panhard rod and the torque arm from the trans to the diff. there are other upgrades you can make that will help
you can use the tranny, and rearend. the tranny will need custom stuff and the driveshaft may have to be custom, but the rearend should fit if you are going disc to disc brakes. it will be about an inch longer on each side though
