91 camaro 5spd 383 stroker (was 305) starter issue
Old 08-27-2015, 11:20 AM
Brodix's Avatar
Default 91 camaro 5spd 383 stroker (was 305) starter issue
When key switch is turned to start the starter just grinds. Not fully engaging. Only thing that works is running a jumper wire with a push button start. I have replaced both positive and negative battery cables, checked grounds, replaced neutral safer switch , starter relay. It seems as if there is not enough power going from key switch to starter solenoid
Old 08-27-2015, 12:22 PM
How many volts do you have on the start wire on the solenoid?
How do you have your ground cables routed....negative battery directly to block and block to frame and body?
Old 08-27-2015, 02:08 PM
Brodix's Avatar
I have 12 volts. And yes I got negative to frame then two grounds from block to frame /body
jimcates3
10-05-2012 09:09 PM
GoingBroke
08-09-2011 07:10 AM
brassknukl
VS
23
03-20-2008 02:44 AM
sshogun
06-04-2006 10:36 PM
Quick Reply: 91 camaro 5spd 383 stroker (was 305) starter issue
