87 Iroc rough idle, rough untill 1800rpm
1987 iroc z z28 tpi, wont idle right, runs rough/stalls untill about 1800 rpm runs great. Plugs all looked the same, i dont think its a stuck injector. Replaced 02 sensor, ign coil, wires, plugs, fuel pressure 30, unplugged mass airflow sensor, runs the same, any suggestions?
How do you know the EGR is good? A stumbling on accelerartion can be another indicator of a weak EGR spring. "Idle seem better" did you do something?
Check engine light?
Check engine light?
